Building AN trans. cooler lines- help!!!
Stainless Steel is not a friendly material to cut.
Keep the cutting edges sharpened and the fastener holding the blades together tight.
These are available at the two largest speed parts businesses we have as well as many other places.
The dremel will throw tiny pieces straight to your face if you are not careful to note rotation of the disc when making the cut- wear a full face shield. You do not want this stuff getting into and eye or two.
At stated earlier, fiberglass covering is easier to work with and also much more flexible and lighter compared to stainless wrap.
