4L60E trans
Old Jun 1, 2019 | 09:15 PM
Chevymanty's Avatar
Default 4L60E trans
The larger plug on the Neutral safety switch box where do these wires go to, (schematic) would be great, thx
Old Jun 2, 2019 | 07:36 AM
bbond105's Avatar
What vehicle is the trans in?
Old Jun 2, 2019 | 07:44 AM
Chevymanty's Avatar
Default 4L60E trans
Hi bond, going in street rod but came out of 2004 Chevy Silverado, 4.8 motor. I did install the stand alone and I think I don’t need it, but not sure, thx,
Old Jun 2, 2019 | 06:21 PM
bbond105's Avatar
Is the Neutral safety switch mounted to the left side of the trans? Try this wed site, they may have the info you need.
http://www.lt1swap.com/
Old Jun 2, 2019 | 06:37 PM
vorteciroc's Avatar
Normally, for 2WD vehicles there would be:
-power to be sent through the starter relay and to the starter motor.
-power to be sent through the brake pedal position switch to the gear selector shift interlock solenoid.
-power to be sent to turn on the reverse lights in "Reverse".
-a ground.
-power in(10A) for starter circuit.
-power in (20A).
Old Jun 2, 2019 | 07:06 PM
Chevymanty's Avatar
Default 4l60e
Thx for the info!!!
