4L65E rebuild questions
Hope you are all having a good day and are happy with your lives.
I have an 4L65E transmission that was fully rebuilt around 7 years ago.
It's still running strong however I have not abused it.
The original power rating of the built transmission was 600hp for maximum reliability but it can hold to 750hp or so before breakages become likely.
I have an LS 408 stroker engine making 650-700hp at the moment and I really want to put a blower on which should net me around 1000hp.
I am aware of the limitations of this transmission and I certainly do not want to push it.
Doing a 4L80 E conversion is out of the question because of the cost involved.
The transmission is in a vehicle with the 2004-2006 Pontiac GTO chassis.
I have noticed from Sonnex, that they have some new parts out for these transmissions:
Sonnax 2nd Gear Super Hold Servo Kit 77911-03K
Sonnax Heavy Duty Sun Shell Kit 77749-02K
Sonnax 6 Pinion Front-Input Planetary 77284-K
Without those three optional upgrades a stage 4 master rebuild kit can support up to 750hp reliably but they recommend for strip vehicles to keep the power to 700hp.
Does anyone know with those optional upgrades if this transmission could hold 1000hp or more than 750hp reliably?
1. the super hold servo is a nice piece. Use it in conjunction with a NEW reverse input drum, and a Carbon (NOT KEVLAR) extra wide band.
2. The sun shell kit is great. Really helps with thrust bearing issues.
3. Do no waste your time or money with this part
Who do you keep talking about "they" recommend. What company are you dealing with.
And no...those parts are not going to be the weak link at your power level.
It also comes ray bestos blue plate frictions.
So is there a way to make this transmission cope with more power reliably?
- Complete Raybestos Blue Plate Friction Kit: Meh. Nothing special but it's a nice friction
- Complete set steels with 3-4 Kolene steels: Again...meh ALSO it doesn't say how many frictions...that's concerning
- Complete gasket and seal kit: $20 whooptie doo. Nothing special
- Wide Raybestos Pro Series Band:Good
- ACdelco 3-4 Apply and Backing plates for proper 3-4 clearance: Likely a .223 and .157 set with .093 snap ring. Again...nothing special
- New ACdelco reverse input drum: This is very good...but you don't need the new apply piston they show in the kit. Use the one from your core
- "Beast" sun shell: Sonnax shell is better...simply for the thrust control
- ACdelco 5 pinion rear planetary gear: If you want to waste a bunch of money...get 5 pinions haha
- ACdelco 5 pinion front planetary kit: Same comment as #8
- Sonnax input drum reinforcement kit: You'll hear different sides to this story. In my opinion, it doesn't fix any problems. It just moves the problem to a different location.
- Trutech Performance Shift Improvement Module: Sounds like a custom shift kit...I doubt they have anything special in here
- Raybestos heavy duty 29 element forward sprag: Good...make sure you prep the race properly
- Complete bushing kit with Teflon front pump bushing: 60e isn't hard on bushings as much as other units. Replace pump bushing, double up sun gear bushing. The rest likely won't need much attention...but inspect them all
- Complete thrust washer kit: your 65 will likely be almost all roller bearings. So you won't hardly use any of this
- ACdelco 3rd accumulator and 3-4 exhaust check valves for hydraulic integrity: The superior k0136 is the best option for the 3rd accum checkball
- 3 input drum bonded steel clutch pistons: Standard with any rebuild
- Sonnax replacement load release springs:Don't waste your time
- Quality OEM filter: who cares
Go read KFXguy's thread...lots of useful info there and I have tried to share some tips and tricks in his thread.
I can be pretty confident in saying that if you just do a standard rebuild with the kit you have mentioned...you're going to be pretty dissatisfied. and Likely smoke a trans
also read cayenne ws6 thread
both have probably 100+ posts in the thread...so get comfy and start making notes
if you read both of those end to end and still have questions, then post back in here and people can help answer
He confirmed with me there is no way this transmission will hold 1000hp.
You might be able get 5 or 6 track runs before it starts to break.
But damn, I wish someone would come out with something that will let these transmissions handle in excess of 1000hp reliably.
That would be so good.
they will warranty 1000 horse.
I would never actually try that...but you go to town haha
750 can and has been done reliably...but not cheaply
Since it is a GTO...I know there are other transmissions that will fit.
About the only cars youre really stuck without a swap are c5 and c6 corvettes...and even then you can get a glide if youre willing to drop the cash
Worked out good.
I will check out that performabuilt place.
There was a guy here though that got his 4L65E to break at 850hp.
If I had the newer HSV which comes with the 6L90E and rebuilt it this would handle 1200hp no problem.
Maybe one day....
And yes we even warranty them at those power levels no questions ask.
What does it not solve? How does it move the problem to somewhere else?
I've seen the snap ring lugs pop off
I've seen the whole drum shatter
I've seen all sorts of things...but the failure rate of "stripped splines" is incredibly low in my personal experience.
I leak test every drum...and after a few years of doing so, I just preventatively press out each and every shaft, apply green loctite, and press back in.
I just don't see the benefit to pressing that collar on...as always Dana, I love to learn and hear other opinions. Why do you like it?
I have yet to have broken one, in our builds with or without the collar.
I feel proper turbine-shaft removal and re-installation in very important here.
When I do come across units, where this drum has failed... The units almost always have had all accumulator function removed.
I personally think that is a huge mistake...
If a builder can not figure out how to achieve the shift firmness that is desired, without removing all accumulator function; then what the hell are they doing, building these transmissions? I don't get it!
