4l80e tran
Old Jun 24, 2019 | 11:50 PM
jertho's Avatar
Default 4l80e tran
can i use a 1997 4l80e in my 1991 3500 c gmc its got a4l80e in it tx
Old Jun 25, 2019 | 05:57 AM
Jays_SSZ28's Avatar
Maybe.
I have a 1997 4L80E in my 1992 3500.
If your '91 has the original wiring harness on the truck you will need to change it.
The cooler lines will need to be adapted.
My trans had a brake on the tail housing, I just tok it off and put the original tail housing and yoke on it.
Been in there for 13 years at least.
Old Jun 25, 2019 | 06:29 PM
jertho's Avatar
yes wireing upgraded the 1997 is slider it has threads can i put yoke on it thank you
Old Jun 25, 2019 | 08:42 PM
Jays_SSZ28's Avatar
What?
Old Jun 26, 2019 | 07:37 AM
MaroonMonsterLS1's Avatar
Is this supposed to make sense in english?
Old Jun 26, 2019 | 11:42 AM
jertho's Avatar
what i meant was 1997 had a slip yoke and 1991 has a bolt on yoke , would the bolt on yoke leak though splines because has no oring on output shaft tk
