Hughes 4l80e
Something just tells me:
"no don't even bother... it won't hold, go with RMVB transbrake TH400 with that money instead and slap on some 3.25's and 28" tires."
Did you mean 4l60e?
Because getting a 4l80e to support 1500hp Can and HAS been done for far less than 10k built with a warranty. Which means there's nowhere near that much in hard parts.
This thread has gotten out of hand.
I've supplied the names of multiple vendors for both the transmission and the torque converter.
Call them and detail your setup and ask their recommendation/pricing/lead time.
there is an abundance of parts (most developed for the th400 that will directly interchange with the 80e) out there that will happily support 1500hp. The weak link becomes the overdrive roller clutch...stock has been pushed past 1500hp and it's usually the splines that strip...so there is an aftermarket option for that now.
Did you mean 4l60e?
I think he meant the car / engine has 10,000 worth of parts
Are you saying you have 10K in the car, or in the engine, or in a 4L80E transmission???
Like Marooney said... I don't see that Kind of money spent on parts for the 4L80E normally.
3,800 Lbs is not actually heavy for a street vehicle... Some of the builders actually rate there units power capabilities for trucks (around 6,000 Lbs).
I personally much prefer the 4L80E for anything in the 1,800 HP range and down.
I then usually go to building a THM400 for street vehicles and a TWO-speed THM400 past that point for track only vehicles. (Power-Glides also end up in that Mix at times too).
They tolerate a HOT transmission and work fine for a track only application... But who teaches all these guys that "Magical clutches" exist???
I’d love to get a 4l80e and enjoy that over drive gear on the highway, but I was advised to just deal with the TH400 or get a glide with gear vendors at that power level.
Here’s a good deal on a 4l80e setup
https://ls1tech.com/forums/market/19...ighlight=4l80e
RPM seems to have a good reputation going. I am not familiar personally with their units to say with any certainty. I'm sure one of the builders here has at least had a peek inside.
To my hearts sadness, my wallets happiness and my brains complete lack of understanding... Transmission built for 1,000+ HP is considered by too many builders to be a "Specialty".
Many builders who do not understand their products and simply build them without any thought process will say that something is not possible or that problems arise.
This is not true in regard to the 4L80E units with 1,000 HP driving them. Many of us build them to double that horse power with out issue.
If those other shops wish to call what I do a "specialty" and farm out the work to me... It is fine by me.
What I do not like, is lying to customers and stating that "it is not possible or is problematic" just because that business can not do, what I and many others do.
For only 1,000 HP... I would build the engine for 600+ HP normally aspirated and go with a single turbo-charger instead of two.
Do not start looking at camshafts yet until you have the cylinder heads and much much more planned out for the engine...
I am very fond of the Y-Block LS Next Aluminum cylinder blocks (not the blocks with the deep skirts removed) and have two of them for myself.
There are many aspects incorporated in this cylinder block that I prefer over any of the production castings.
However for low power production... It is too expensive in my opinion... If you have a ton of $$$ then go for it! It's Awesome!
Sorry... New Engine Thread Please... and drop a hyperlink... do not continue here... Thank you :-)
If I built it...it might fall apart.....lol
