Need help with correct flexplate for LS3/4l80e
Old Jul 20, 2019 | 03:46 PM
85LSXTRUCK's Avatar
Default Need help with correct flexplate for LS3/4l80e
I installed motor to trans and dropped it into my g body and I didnt realize there are 2 different bolt pattern flexplates. Most likely I have the 11 1/2 bolt circle and I need the smaller bolt circle. I have a yank pro converter if that helps and i was using the spacer. What flexplate do I need please? Only going to be in the 500 hp range with this LS3.
Old Jul 20, 2019 | 06:59 PM
LLLosingit's Avatar
I would call Yank and ask, We did a Yank 4L80E converter and we had to use a flexplate for a 4l60e that came from a 5.3 truck engine.
Old Jul 21, 2019 | 08:26 PM
stilealive's Avatar
If this one works for you, I'll sell it to you. Brand new in the box. $375.00 shipped. Not sure what shipping cost is, its a heavy sucker.
PM me if interested........
https://www.ebay.com/itm/FP300-Mezie...02dc9b7d40e547
Old Jul 22, 2019 | 03:44 PM
85LSXTRUCK's Avatar
I took it to work and modified it to work, I should be good to go now.
