4L80E Pan with no drain plug
Old Aug 4, 2019 | 09:09 PM
Novapat67's Avatar
Default 4L80E Pan with no drain plug
I just went to drain the fluid on my 4L80E to start installing my HD2 kit. There is no drain plug! There is just a flat boss where the plug should be. Is this common? I'm sure I can get a drain plug from the parts store. Do I just drill and tap it for the new plug? This is a first for me. The trans is from a '96 Pickup.
Old Aug 4, 2019 | 10:35 PM
Lsx Rubi's Avatar
It is fairly common to have no drain plug . Probably better of just buying a pan with a drain plug . Because i think you would have to drill and weld a nut/boss for the drain plug .
Old Aug 5, 2019 | 01:45 AM
LLLosingit's Avatar
They make a bolt in drain plug . Dorman 65128.
Edit: Link to plug removed because this site seems to be redirecting to Walmart instead of the Amazon link I originally posted...What kind of BS is that!
Old Aug 5, 2019 | 10:28 AM
Novapat67's Avatar
Thanks! I just ordered that plug!
Old Aug 5, 2019 | 10:57 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
That flat boss, if it's on the bottom surface, it's probably where the magnet is sitting.
