Where did 2nd gear go?
EDIT--took it on a test run this morning and no 2nd gear at all.
Can't be the shifter or linkage or it wouldn't work in the burnout. Tried it on the return road and nothing there either. Any thoughts?
it was supposedly built to handle 900hp.
”Full Race” with reverse manual valve body and a brake.
I’’m only putting just over 400 to the tire and not using the brake yet
It should have a 4L80E sprag type drum, or if one can be found a sprag type th400 drum, or aftermarket.
When I had a RMVB 400 I'd start my burnouts in second and just take it up to whatever rpm and roll out. It was behind a big block that would rev to 8500 rpm if needed. So I didn't need to shift in the water box.
People damage the intermediate 4L80E type Sprags often from misuse...
Even the larger Caddy 4T80E sprag that gets converted over as an intermediate THM400/ 4L80E sprag is not indestructible.
I often use these in our customers builds along with an outer race that I machine with varying heights for either 4 OEM waved THM400 frictions (My Preference) or 4 OEM 4L80E frictions.
When using a low power/ low RPM engine like the OP... the OEM THM400 intermediate sprag (if you find one) or one-way roller clutch should hold-up fine.
Speaking of sprags... anyone have a 64, 65, or 66 reaction carrier to sell... I am running low on these and like to hoard them... I had sprags made but need more carriers.
People who are not in the know (as far as our transmissions go), often interchange the names/ terminology of different one-way clutches.
Whether a ratcheting type, roller type, sprag type, or other style not commonly used in our transmissions...
Most other industries interchange these types/ terms fluidly.
So is it coming apart yet?
I have another thread labeled disaster on the dyno to explain what happened with the truck and 4l80 only three weeks ago
