TH400 Trans Brake Problem........
Old Jul 14, 2004 | 03:41 PM
BIGBOS's Avatar
Default TH400 Trans Brake Problem........
What would cause this.....
Hitting the brake button, flooring it, it flashes to my stall area 4K, then drops to 2300ish and stays there........it won't stay up and stay loaded?
Any idea what would cause this?
The only way I can launch it hard is by flashing it real quick and letting go of the button......
Old Jul 14, 2004 | 07:16 PM
john kilgore's Avatar
Default stall
your tc is the problem.
Old Jul 15, 2004 | 11:47 PM
Fast SS on TNT's Avatar
I concur, it has to be a torque converter problem. Pull it and get it checked.
Old Jul 16, 2004 | 04:05 PM
BIGBOS's Avatar
K, thanks....
I just had the thing rebuilt
Old Jul 18, 2004 | 12:30 AM
BIGBOS's Avatar
To the TOP
Old Jul 20, 2004 | 09:12 PM
BIGBOS's Avatar
I think it might for sure be the converter, tonight while driving my crusing temps were at 210, they are usually around 150-160......it has to be the converter slipping
Old Jul 21, 2004 | 01:15 PM
BIGBOS's Avatar
To the TOP
Old Jul 21, 2004 | 01:22 PM
CHRISPY's Avatar
sounds like converter man
Old Jul 21, 2004 | 01:36 PM
c5ls1vette's Avatar
convertor problem, been there and done that.
Old Jul 21, 2004 | 03:09 PM
BIGBOS's Avatar
That could explain why my MPH is down too.......
damn P.I. converters
Old Jul 21, 2004 | 03:41 PM
JZ'sTA's Avatar
I would try TCI or Yank as well, seems their converters work well.
Just a idea if you dont mind buying from a non sponsor, call Neil Chance and Coan.
I am in the market for a new converter and they have both been really helpful.
Coan has the better C/S.
Old Jul 21, 2004 | 06:07 PM
Zo6Killer's Avatar
I'm almost sure it's a conv. problem. We had trans. brake problems on our '65 Nova. The solenoid went dead and we had to footbrake. That one was a TCI. Problems can arise from even good parts. That's the lesson I learned there. Good luck!!!!
Old Jul 21, 2004 | 06:09 PM
CHRISPY's Avatar
TCI converters are priced well AFAIK and are supposed to work very well
Old Jul 21, 2004 | 06:51 PM
KRAZY K 2000 TA's Avatar
Default convertor
I agree on the convertor,would not run it anymore though could already be on your way to a new trans if there are metal shavings it is through the entire trans ,including the cooler,wiped out a brand new c6 from a converter in my mud truck
Old Jul 21, 2004 | 07:26 PM
BIGBOS's Avatar
Yea, I looked at the fluid on the dipstick, has good color and there is nothing in it........
