4l60e no reverse or neutral
Now on top of this it will not crank like it's not in park. It will not crank in neutral either.
Just trying to get some thoughts on what I should look for when I tear it down, how maybe I could by pass the neutral safety switch just so I could move it, will engaging the starter work etc. I'm thinking some of the discs are welded together, maybe a broken subshell also.
Thanks for replies in advance
The low roller is broken and the forward sprag is rolled over. Either way if you miss the problem haul it to a professional.
I will 100% guarantee, I'll bet you the cost of a new stage 10 4L79EHD that the clutches are not welded together.
NOW unless you're not telling you did some dumb **** like held it at WOT in gear without the tires moving at all, yea that will fuse clutches together, did you do that?
When's the grand prize being given? You just going to say **** it and put a used one in and turn this one in for a core?
Let’s back off the a-hole throttle a little and ask a very simple question.
What does the fluid look/smell like?
Pulls normal in other gears, still has 3/4 (at least that's what I'm assuming he means by "shifts out" aka shifts through gears like it should)
If the Low roller was broken, it wouldn't move forward in D...same goes for the input sprag. If that was busted, he wouldn't have 2nd or 3rd without having the shifter in D2 or D3
forward in neutral...yep sounds like welded forward clutches.
I'll shoot you my address for the check to that level whatever expensive trans.
OP...yank the trans. Share pics of welded forwards. If it's not forwards...send extra pics of whatever it is!
You've seen forwards welded together, anyone ever tell you what they did? I'm guessing no or they forgot or forgot to tell you that part.
Sure the forwards might be welded together, depends on how long it was held in drive with throttle and not spinning tires.
Forward sprags don't always break and let go 100% same with low rollers.
I'm done with the god damn guessing games.
I have my vision of rocking a truck to get it unstuck. It wouldn't fuse a clutch. I guess I take peoples word to be accurate, shame on me.
