Silverado trans wtf happened
Old Jan 6, 2020 | 04:59 AM
Dennis Helton's Avatar
Default Silverado trans wtf happened
05 Silverado 4l60 4x4 half mile outta town gradual acceleration no noise no smell no warning neutral fluid may be a little over full looks good smells fine no gears no torque park is park R-1 jack wtf happened to my $#/+
Old Jan 6, 2020 | 06:57 AM
MaroonMonsterLS1's Avatar
that was pretty incoherent but what I got out of it was that you were driving along and then it felt like the trans got shifted into neutral. No gears available, not even reverse.
If that is the case...broken pump rotor.
Pull the trans and fix it. If it scarred the pump you may need to replace the whole pump.
Best wishes.
Old Jan 6, 2020 | 04:59 PM
rpturbo's Avatar
Sounds like the cable came off. It's a fairly common issue on those. Most of the time it pops off on the trans lever. A bread tie will help hold it on, but normally once it starts, you need to change the cable out.
Old Jan 7, 2020 | 12:26 PM
No cable is still on it idk what was incoherent about my post you seem to pick up what I was laying down any update I pulled the lines off the radiator and cooler it didn't make a big *** mess like it should of I figure I'm pulling it anyway
Old Jan 7, 2020 | 02:14 PM
Sentences and punctuation help to make your point more clear.
If you pulled a cooler line and started the truck and nothing pumped out...then the pump is broken.
Remove and disassemble
