4l60E rebuild issues
I Have seen a bad park/ neutral switch cause what you are experiencing, as well as a bad PCM.
Do you have any DTCs?
On rare occasions I have also seen a separator plate/ gasket mix match cause similar conditions.
Make sure the PCM can see the gear selector potions correctly first.
Did you jumper both sides of the neutral safety circuit together so that the engine will start???
If the PCM sees the manual valve position, incorrectly in neutral... the PCM will not command the pressure control solenoid to allow line pressure to rise the same as if in gear.
Please explain how you have the PCM/ transmission management installed and configured.
I'm guessing the neutral safety wires were jumped to get the engine to run.
