6l80e Shifting Weird
Also might recommend a fluid flush including trans cooler, replace filters, and verify trans temps.
These 6Lxx transmission generate more heat than the 4Lxx and also need to run cooler. So where a 4L80 might be fine running around at 170*, the 6L80 runs better in the 150-160* range.
Then clear the adapt values and do a quick relearn on the trans. If that doesn't clean it up...report back and we can go from there
I cleared codes and did a relearn the other day and it started doing the same things over again. The only new code pertaining to the drivetrain is a knock sensor, which I plan to replace this weekend while I am home from school.
Thanks in advance
Look at the misfire counter on a quality scanner or on the laptop with HPtuners etc
If it's racking them up...fix that before blaming the trans
