Dipstick tube for swap
i have in 83 jag xj6 and have swapped in a 94 lt1 and 4l60e from a formula, looks like it was made to to go there with one exception...
the trans dipstck and Tube, come up then point a long way forward.. im looking for something that will put it back at rear of engine and pointing up..
looked at an impala but it appears to do same thing... maybe a pickup??? But don't want it too tall... any help greatly appreciated.
thanks
Darren
Not sure, but this might work for you:
https://www.summitracing.com/parts/tci-743865
And due to its size and weight, the pipe bender tends to be cheaper locally than on Amazon. Here is a typical tool at HomeDepot:
https://www.homedepot.com/p/Klein-To...6207/100660160
But maybe someone else has a better choice or idea...
Also, to avoid the extreme mess of dropping a full trans oil pan, I first stick a $10 Harbor Freight fluid pump down the dipstick tube to suck most of the fluid out.
