Installed Circle D 3600
Floored it off idle, does it look like its flashing the right RPM?
A stock/ stock-ish LS1 does not produce enough low-speed torque to achieve the rated brake-stall speed.
I am not familiar with Circle-D products specifically... But it looks to be the "softer-hit" type of converter; or that engine is a real dog.
Low-Speed Torque is what will most greatly effect stall-speed.
That small, higher reving engine does not produce enough power to reach the stall-speed rating.
