4l60e issue nobody can figure out
Old Jun 26, 2020 | 11:37 PM
MaroonMonsterLS1's Avatar
That is not the issue at all.
OP, what version of HPT did you pull the tune with? I am unable to open it.
Logs I can see.
Old Jun 27, 2020 | 11:01 AM
Colorado24's Avatar
Logs I can see.
its showing version 4.6.3
Old Jun 27, 2020 | 11:07 PM
Diable tap up/tap down and make all the tap tables match your "normal" shift pattern table
Also, make "normal", "pattern A" and "pattern B" match.
Pattern A can be different if you have issues with lots of up/down shifts while in cruise control...but I usually have them match and have success.
The only 3-4 shift situation that makes any sense is the tap up/down table and the weird break at 25% throttle and 74mph...then the next cell is like 83 mph...
None of the other shift tables show anything around 74mph that I would call an anomaly.
Old Jun 27, 2020 | 11:48 PM
vorteciroc's Avatar
Very interesting.
Old Jun 28, 2020 | 04:36 PM
Colorado24's Avatar
i really appreciate the advice but i am a little hesitant to start changing things in the program since i have never done anything like this before. Looking at it i think i know what you are talking about but i am scared I'm gonna mess something up
Old Jun 29, 2020 | 09:06 AM
I mean...it's already messed up. That's why you're here
Save the file you have in the truck now and name it something obvious.
Then re-save the file with a different name and make your changes. If you get on the road and you don't like the changes, or **** isn't working right...just flash back the file you already have in there.
Best case scenario...you fix it.
Worst case you're right back where you are now.
Old Aug 19, 2020 | 03:03 PM
Colorado24's Avatar
Well the issue has been solved by making table 15002 the same as 15000
Old Aug 19, 2020 | 03:21 PM
15002 and 15000
Don't have my HPT in front of me to look...which tables are those?
Was it the tap up/down tables?
Old Aug 19, 2020 | 04:05 PM
Colorado24's Avatar
15002 and 15000
Id have to look at hp tuners but i left my laptop at work. But i believe it was the hot and cold shift tables.
