Easy upgrades during pan swap
Old Aug 19, 2020 | 12:09 PM
kdick91's Avatar
Default Easy upgrades during pan swap
I'm knocking out a leaky pan gasket and going with a deeper track pan/filter combo and wanted to see if there was anything recommended to knock out while the pan is off. It's a stalled, cam only T/A. Way back when, people recommended shift kits. Is that a worthwhile venture for a 30k mile 4L60E? Hoping to get a built unit in within the next 1-2 years.
Old Aug 19, 2020 | 12:22 PM
MaroonMonsterLS1's Avatar
What vehicle?
LB1 boost valve is always a good idea.
Shift kit if you're wanting to drop the valve body
Old Aug 19, 2020 | 06:31 PM
kdick91's Avatar
Sorry, it's a 2000 TA. I don't mind dropping the VB, just don't want to pull the trans again till the built one is ready to go in.
Old Aug 20, 2020 | 12:09 AM
vorteciroc's Avatar
Like Maroon Monster said, without at least dropping the valve-body... there is not much you can do.
On F-Bodies, usually there is not even enough room to change out the servos... bummer.
Old Aug 20, 2020 | 01:59 AM
sjsingle1's Avatar
correction.....if you still have worn out rubber motor mounts....removing the tranny cross member will allow it to drop enough to remove the servo.....piece by piece .....ask me how i know
Old Aug 20, 2020 | 07:49 AM
shift kit, boost valve, that's about the end of the list
Old Aug 20, 2020 | 11:43 AM
kdick91's Avatar
I'm good dropping the VB, that's not awful under the car. Looking at the TransGo HD2 (is this one recommended?), there are several internal pieces to the kit as well. Is it worth time/effort to only install the stuff accessible with trans installed? I have poly motor mounts and very little willingness to pick out a servo piece-by-piece lol
