Stall problem?
Old Jul 13, 2020 | 05:41 PM
  #41
schtick's Avatar
Really. 😀 Where I grew up we called it a stall. Just like cement isn’t “suhment”...it’s “SEEmint”. 😀
Old Jul 13, 2020 | 05:54 PM
  #42
vorteciroc's Avatar
Originally Posted by 00pooterss
uh oh, pc principal in the house
lmao!
Old Jul 13, 2020 | 10:04 PM
  #43
98CayenneT/A's Avatar
Originally Posted by 00pooterSS
It's been 10 years but if I recall correctly the SS series is supposed to have a 97% efficiency rating, if that helps you at all. I don't know how to get to the percentages you did (the math)
and I'm assuming he has a SS
My math was just done quick with the 80mph at that rpm if the converter was locked - 30% = his actual speed of 55mph.
80mph - 30% = his 55mph at 6200 rpms. So 30% slip. Far from precise due to not know exactly what rpm he is shifting at but his tuner should be able to give him a pretty close % using rpm vs output shaft/vss I would think.
Punching in his specs into a slip calculator I end up with around 40% slip.
In a healthy converter it is less efficient the lower the rpms and as the rpms increases the slip % should drop.
I go anywhere from 12 % in lower rpms and in 2nd gear to around 8-9% at the top of 3rd and obviously my 1:1 gear.
None of the numbers I gave are absolutley precise for his converter or mine but they are also not far off. Lots of little variables......
Old Jul 13, 2020 | 11:07 PM
  #44
vorteciroc's Avatar
Ouch!!!
Old Jul 14, 2020 | 09:44 AM
  #45
FTICONVERTERS's Avatar
LS1Tech Sponsor
Originally Posted by schtick
I see. I'd imagine there's a price difference between a restall and a rebuild then?
Situational, that depends on parts and work needed.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jul 14, 2020 | 10:53 AM
  #46
00pooterSS's Avatar
Ah gotcha. And makes sense, pretty simple and easy way to get to a really close estimate of efficiency. And at the rpm he was at at 55 mph (around 6k) that converter should have been in full stall long before that. And his particular stall again I believe is supposed to only have around 3% slip once in full stall. I don't see it on the website but I believe that's the number I saw when I bought my SS3800 in 2010. Either way, that thing is shot lol.
Old Jul 14, 2020 | 11:29 AM
  #47
schtick's Avatar
You all don’t have to keep rubbing it in. Haha
Old Jul 14, 2020 | 11:47 AM
  #48
If that was your first converter you are going to be floored with a mechanically right one along with spinning that thing higher
Old Jul 14, 2020 | 12:35 PM
  #49
00pooterSS's Avatar
LOL
Full agree
Old Jul 14, 2020 | 01:40 PM
  #50
schtick's Avatar
I'm looking forward to it. The A/C in my house crashed yesterday so I'm going to have to try to find a way to finance a new/rebuild CONVERTER now.
Old Jul 14, 2020 | 01:42 PM
  #51
00pooterSS's Avatar
lol CONVERTER
Sorry to hear about the a/c man, that's a f'ing bummer.
If it makes you feel better...
when I was mowing my yard last night I hit the wiring for my ac unit with the weedeater and ripped the wiring out of the unit and then in a fit of rage I threw the weedeater at my neighbors fence (long standing issues with them and their fence and their dog and throwing trash in my yard) and I had to stop mowing and fix my ac.
Then after I repaired all the wiring I picked up the weedeater and it wouldn't run at all, have no idea why but something on the fuel side went to **** and I had to pull all the hoses and tank and clean everything and redo all the hoses and clean the carb to get the weedeater to work again, so then I was outside mowing until almost 9:30 at night..
But it gave me the opportunity to drink more beer while mowing so that worked out at least.
Old Jul 14, 2020 | 01:50 PM
  #52
Fact:
Torque Converter > home a/c
Old Jul 14, 2020 | 01:56 PM
  #53
schtick's Avatar
lol CONVERTER
Hahahahahahaha. You're like that guy I've seen online that loses his **** over his weedeater and smashes it about 100 times in his driveway.
  #54
schtick's Avatar
Fact:
I'm going to show this to my wife. I think it will be enough to convince her.
Old Jul 14, 2020 | 05:49 PM
  #55
00pooterSS's Avatar
I am that guy
Old Jul 15, 2020 | 10:04 AM
  #56
LS1Tech Sponsor
Goodluck in your endeavors sir!
IF you survive to tell the tale, please report back here with your results. you know.... for science
__________________
1-866-726-8358
FTIPerformance.com
Old Jul 15, 2020 | 10:58 AM
  #57
Dragframe's Avatar
where you from? I’m a HVAC tech out on workers comp. maybe I can help ya get ac and a new stall lol
Old Jul 15, 2020 | 12:12 PM
  #58
schtick's Avatar
I'm in MO. But my uncle does HVAC so he's on top of it. So thanks for the offer. If you have a free CONVERTER I'll take that.
Old Jul 15, 2020 | 01:06 PM
  #59
Didn't learn your lesson the first time.... kidding.....a bit.....kinda.... but not really.
Old Jul 15, 2020 | 01:44 PM
  #60
Dragframe's Avatar
got a 3000rpm circle d converter with 700 miles on it I’ll sell ya 🤪
