JW Bellhousing bolts?
Old Jul 23, 2020 | 06:40 AM
amiller2897's Avatar
Default JW Bellhousing bolts?
I’m looking everywhere and getting nowhere
I have a 2005 LM7 gen 3 engine and a TH400 with a JW bell on it.. I have no bolts for it so I’m looking on amazon for some. Will M10x1.5 44mm work? Which is about 1.75” long ... I know the bell is thicker than stock th400 bell correct? If that’s too long what should I be ordering, 35mm or 40mm?? I’m trying to order ASAP to have by Saturday thanks in advance!
Old Jul 23, 2020 | 07:11 AM
MaroonMonsterLS1's Avatar
You haven't been looking everywhere. You've been waiting for a spoon fed answer on here or another forum.
I can tell you that a GM transmission designed and built in the 60's isn't going to be metric thread...
5/16-18 thread 1 3/8" long is STOCK
Measure the bell and get a bolt that is 1 3/8 + bell thickness
something flanged will work best to seal
Old Jul 23, 2020 | 07:14 AM
Ok so if I haven’t looked on the Facebook groups and forums , why do I keep coming up with m10x1.50 ..... I didn’t just pull it out of thin air. Instead of being an dixk, why don’t you just help like this forum is for?
Old Jul 23, 2020 | 07:23 AM
not to mention it clearly states in my post that the “60’s TH400” has a JW bellhousing on it which was made and cut 2 years ago which was 2018 if you’re not away. AND ALSO THE BELLHOUSING BOLTS THREAD INTO THE 2005 BLOCK. So now you sound dumb and wanted to be a dixk for what reason? I didn’t know 2005 LM7’s didn’t use metric ... because I’m pretty sure they do. You know, m8x1.25.... m10x2.0 ... etc. try to have a good day , ask your girl for nudes or something cus clearly something is up with you
Old Jul 23, 2020 | 08:31 AM
HAHAHA
A. the bellhousing bolts onto the pump of the transmission. Figured that's what you were curious about
B. the bellhousing to block bolts...don't need anything special
C. Get the calipers out and measure the depth of hole on the block. Then measure the bell...then do some addition.
D. I didn't think facebook and/or forums were needed for these kinds of questions. If you can't figure out what bolts to use for the bellhousing to block...maybe put the wrenches down
Old Jul 23, 2020 | 08:57 AM
You were dropped on the head a few times as a baby, weren’t you?
Old Jul 23, 2020 | 11:19 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
The depth of the hole in the block does not mean how much (depth) of it is tapped. Take a known bolt (longer than necessary) that screws into the block by hand (try a few holes, or all because they might not all be tapped to the same depth). Bolt original length minus amount that sticks out equals amount needed in block added to bellhousing thickness equal necessary bolt length. Whatever the thread of the test bolt (metric or USA) should be available locally to you. USA grade 8 or metric 10.9 grades. For something like that I would use a flanged head fastener.
Old Jul 23, 2020 | 06:33 PM
vorteciroc's Avatar
I also assumed that the bolts being discusses were for the Ultra-Bell to attach to the pump... LOOOOOOOOL!
Old Jul 23, 2020 | 06:42 PM
I don’t get why when I said “and a th400 with a JW bell on it” .... lol I mentioned the 2005 lm7 because that’s what I need the bellhousing mated to. I got 1.71” long Which is I think 44mm, is that too long ?
Old Jul 23, 2020 | 07:14 PM
01CamaroSSTx's Avatar
Caliper gauge will be your best friend here? I'm getting ready to be mating a glide to an LS and haven't gotten around to determining the exact length I'm needing. Guess I could make that my short project to go with some cold beer this evening..
Old Jul 23, 2020 | 07:40 PM
M10 X 1.5 X 45MM
Will work...
Old Jul 23, 2020 | 07:45 PM
Sounds good man they should be in tomorrow morning so I’m gonna have a couple beers as well Saturday and get this trans in place so I can build my hotside piping and get this thing going lol
Old Jul 23, 2020 | 09:01 PM
vorteciroc's Avatar
LOL!
Well for a few reasons, i guess...
1. You never specified the name or type of bolts being discussed (You could have said: "Transmission to Engine Mounting-Bolts").
2. When someone brings up a "Bolt-On" Transmission Bell-Housing and asks about unspecified bolts... We think: Okay, bolts for the "Bolt-On" Bell-Housing.
3. Most people would have any easy time finding bolts to attach the transmission to the engine... Compared to Transmission Pump-Bolts that are long enough for a "Bolt-On" Bell-Housing.
By the way... Did you also purchase extra-long Dowel-Pins to locate the Bell-Housing to the Engine?
If not... They are cheap, available from Summit-Racing, and worth the money and hassle!
Old Jul 24, 2020 | 07:10 AM
Better give him a part number.
He wants that internet validation so he can be confident in his purchase cuz he's clearly not confident enough to do these things on his own.
OP: sorry if I came off "sideways" in the first couple posts.
Old Jul 24, 2020 | 11:21 AM
vorteciroc's Avatar
Summit Racing Part #ICB-551334
From ICT Billet: $14.99
