a10 in a 4th gen?
Old Jul 30, 2020 | 08:53 AM
merim123's Avatar
On the point of 'crispness' @RPM WS6 - It just feels better to drive. It isn't like a CVT in my mom's subaru type and it's not like a manual, but it is a better experience just driving. Like others said, once you drive it, you'll feel it. It is better than a 3sp or 4sp auto on the street. I'm not comparing to racing.
As to buying a 6th gen or not, At 6'3" I can't fit in that car anymore. Sat in a ZL1 and it had a sunroof and I hit my head. Same for the C7. The last car I could fit in very comfortably was a 5th gen 1LE with recaros and a c6 vette for context. Plus, a lot of us still left on this forum still have a 4th gen that is a TOY. it's not a daily driver and doesn't cost me much to keep it around and it's one of the few things that I can play with to relax. So i research what I would do next if I could.
Like @vorteciroc said though, GM has taken the path of integrating everything on the CANBUS, so the road to just putting it in with existing wiring, needs a lot more wiring than ever before. Mercedes BMW, others have been doing this for many years. It's going to take time to make it work. It's good it actually fits physically. now we wait for the controller that has to be coming.
Old Jul 30, 2020 | 08:57 AM
merim123's Avatar
more research... this is a pretty good breakdown with pics...
https://www.transmissiondigest.com/f...sor-functions/https://media.gm.com/media/us/en/gm/home.detail.html/content/Pages/news/us/en/2016/may/0511-10speed-gm.html
Additional highlights:
  • Creative packaging – The 10-speed is approximately the same size as the six- and eight-speed transmissions, minimizing changes to vehicle interfaces.
  • Quicker shifts than a dual-clutch transmission – Testing has shown faster upshift times than the Porsche PDK dual-clutch transmission. In fact, the 1-2 upshift is 36-percent quicker than the PDK, while the 2-3 and 3-4 upshifts are 27-percent and 26-percent quicker, respectively.
  • Reduced spin losses – Thanks to only two non-applied clutches – the same number as the eight-speed – as well as other design features, the 10-speed automatic has lower friction that contributes to greater fuel efficiency over GM’s six- and eight-speed automatics. New ultra-low viscosity transmission fluid also reduces friction, while an internal thermal bypass allows the transmission to warm up faster – attributes that enhance fuel efficiency
  • GM-developed controller – It is the latest transmission to use an all-new, GM-developed control system, with performance calibrations tailored specifically for different vehicles.
OR for more than these cars cost new...27.5k problem solved.
http://www.speartech.com/product_p/lt410l90-pp.htm
Old Jul 30, 2020 | 09:47 AM
Bspeck82's Avatar
At that point of rather give ATI a ring and have them build me the baddest 3 speed with OD out there...just thinking out loud.
Old Jul 30, 2020 | 06:28 PM
vorteciroc's Avatar
Originally Posted by kinglt-1
Yes which is why I have a 6th gen...however I still think it would be cool to have a A8 or A10 swapped 4th gen. Honestly the A8 is a beast once tuned.
Sorry to break the news to you...
But the GM 8-speed is complete garbage...
Even GM has deemed it a complete failure.
Old Jul 31, 2020 | 09:25 AM
kinglt-1's Avatar
Not really... The only problem with the A8 is it suffered from torque converter shudder which isn't specifically a transmission problem. When a clutch fails on a Manual do you blame the transmission? Gm programmed the converter to slip in and out of AFM mode so it was a seamless transition which was a fail. Between that and the type of fluid that was used, it caused the converter to shudder in a lot of 8l90 equipped vehicles. I haven't had any issues with mine but I tuned it and turned off AFM shortly after I bought the car. Other then that the A8 is a 800whp capable trans in stock form that has been deep into the 9's and 60ft in the high 1.4x range on the stock converter. With a converter swap they have been in the 1.2's...the A10 hasn't been able to replicate the same numbers...especially the 10l80 in the SS. The 10l90 A10 in the ZL1 get's close. Either way I can't think of many Automatics GM produced prior that was capable of those times factory stock down to the converter...can you?
Old Jul 31, 2020 | 02:31 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I agree the A8 isn't great with the factory tuning, but a built A4 is nothing like a tuned A8 or stock A10 transmission...literally not even in the same ball park. Actually I prefer a tuned A8 over factory A10. The overall driving experience is night and day better. Much faster and crisper shifts...you can just hold the left paddle before you enter a turn and it will drop right into the optimal gear for the speed you are going. It is a lot more engaging to drive spiritedly.
The A8 experience that I has was with a Camaro SS that had been tuned by a local shop, not sure how extensive the tuning was but I would *still* prefer a properly setup A4 based on that experience. I'm sure some of this is just a matter of personal preference. But as for the A10, I can't say anything good or bad about it yet as I still haven't driven one.
Stalled A4 cars feel like you are revving to the moon to putt along or stuck at 6500rpm when you go WOT....like a light switch, there isn't much in-between. Not really knocking them being I drove one for 10yrs and they are fun but the new Automatics are just better all around.
Automatics with too high of stall speeds for the setup and/or very low quality units will in fact feel like you're revving to the moon just to inch up in traffic, I agree. But I've never had that experience, or at least not to a degree that was personally bothersome, when the stall speed was well matched to the setup and was a high quality unit. However, I do agree about the "light switch" effect when going WOT, except that I see this as a positive thing - full power the instant you want it, like a switch. If shift extension is ideal for the setup then you're always going to be somewhere between peak torque and peak horsepower any time that you maintain WOT. Again, I have a feeling that driving style/personal preference plays a big role in how positive/negative these attributes are as well.
But getting back on point, perhaps the advantages of an A10 swap into an older application, such as a 4th gen, would be largely a subjective matter. I don't know that there is any objective benefit when you consider all the cost and hassle involved vs. the tangible gains, but if one is looking for a certain "feeling" that can only come from the A10 then perhaps it's worth it.
Old Aug 3, 2020 | 08:54 PM
vorteciroc's Avatar
Let me know if you make 100,000 miles.
Old Aug 4, 2020 | 05:36 AM
War Prayer's Avatar
a lot of 4l60s in modded cars don’t make 100k either. Kind of a moot point.
Old Aug 4, 2020 | 02:52 PM
dixiebandit69's Avatar
Yeah, but the 8-speed is SUPPOSED to be a huge improvement on the 4/6 speeds (you can add me to the camp that says 6 gears is enough for a street. The reason for the high-gear-count transmissions is just to keep the engine in its sweet-spot for emmisions and mileage reasons.).
I, for one, would love to hear vorteciroc **** all over them some more; it's fun hearing an expert detail how bad a particular part/ system/ car is.
Old Aug 5, 2020 | 07:42 AM
MaroonMonsterLS1's Avatar
10 speed is an attempt at having a CVT without the **** that comes with a CVT
Old Aug 5, 2020 | 04:09 PM
vorteciroc's Avatar
LOL!
Old Aug 11, 2020 | 10:03 PM
  #32
jhshnh's Avatar
I know a few people launch in second gear and bypass first on those ten speeds because the first gear ratio is so low.
