a10 in a 4th gen?
Old Jul 27, 2020 | 07:45 AM
merim123's Avatar
Default a10 in a 4th gen?
I see a lot of people being positive on the a10 in mustangs. I have one in my escalade and really like how it shifts. Anyone thinking about these in a 4th gen? will they even fit? controllers?
Old Jul 27, 2020 | 02:21 PM
MaroonMonsterLS1's Avatar
the 10 speed automatic that ford and gm worked on together? Is that what you're referring to?
If so...I currently know of nobody that has swapped one into a 4th gen. No aftermarket controllers.
Best bet would be to use factory gm ECU/TCU combo for that setup. A whole pullout from a wreck would be the way to get all needed components that communicate
Old Jul 27, 2020 | 09:22 PM
merim123's Avatar
yes, that same a10. wiki is showing it in these cars...
10L80 MF6[edit]
10L90 MGL[edit]
Old Jul 27, 2020 | 11:30 PM
Tyler Dietzenbach's Avatar
This would be awesome....love the 10 speed.
Old Jul 27, 2020 | 11:33 PM
98CayenneT/A's Avatar
2/3/4 speed + loose converter > A10
Old Jul 27, 2020 | 11:37 PM
vorteciroc's Avatar
I have one running in a tube-frame car that I use for R and D.
I had to use the original ECM, TCM, EBTCM, TCSCM, BCM, VCIM, IPC, and the original pair of UBECs, pair of IPBECs, rear compartment BEC, and all the original wiring...
The High-speed/ Low-speed data lines want to see most everything that belongs in the car... otherwise U-Type DTCs start piling up and shutting down systems.
Until programming becomes more available to eliminate most of this crap...
I do NOT recommend it.
Old Jul 28, 2020 | 07:59 AM
merim123's Avatar
I do agree with you it's not ready yet.
I also didn't think GM would make it easy, CANBUS will rule more often it appears as they try to integrate everything on that network. will be harder down the road to run these systems unless companies make their own controllers and sell them. I see speartech has some kind of offering but for the new LTx/10L90 combo.
http://www.speartech.com/product_p/sa-ltx-10l90.htm
Holley has the Term X running the new DI LTx engines but still needs the 4L60/80 only it appears. which are far easier but no 10 speed support yet.
Also, the BMW guys have cracked the DCT trans and that controller is 1k. I would think with these things landing in a lot of cars, we should see some aftermarket support on standalone controllers hopefully.
https://www.dkgecu.com/l/what-is-dkgecu/
Old Jul 28, 2020 | 08:45 AM
Yes. In due time these swaps will be a reality for a large population
Just like in 1999 an LS swap was big money and big hassle. The tuning and understanding took time.
Same for this.
Old Jul 28, 2020 | 10:48 AM
kinglt-1's Avatar
At the track sure on the street I would much rather have a A10. It will keep the engine up in power even with a tight converter while maintaining great drive-ability and better fuel mileage.
Old Jul 28, 2020 | 11:55 AM
Ya, guess I never looked at it like that for the daily driver
Old Jul 28, 2020 | 12:52 PM
LSleeper1500's Avatar
10 > 8 > 6 > 3/4 auto's. GM and Ford both build them, yes. But the Ford has slightly different internals and ratios. Do it.
Old Jul 28, 2020 | 05:56 PM
vorteciroc's Avatar
I personally see no benefit in more than 6 gear ranges...
The now old Borg Warner T56 sold me on a double over-drive six speed.
8 and 10 speed units often do not use every gear range for normal driving.
Some times first gear is only used for hard acceleration, as the unit will start off in second or third gear.
Old Jul 29, 2020 | 03:14 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I agree. While the 2 or 3-speed isn't necessarily ideal for a daily driver (especially when cruising at higher speeds and/or with a loose converter), with an A4 you have OD and lock-up (I do realize that some A3 transmissions also had a TCC, but those still don't have OD) so I don't really see any worthwhile net benefit to all the added cost and complexity of an A10 swap over an A4 with an optimized stall speed in a car that is already set up for such (street OR track, IMO).
Old Jul 29, 2020 | 08:50 AM
merim123's Avatar
I daily drove a t56 for many many years. that was my choice always and really enjoyed the tr6060 in my c6z when I had it. Up until this 10sp, most if not all the automatics I drove from GM felt that lazy acceleration and never had that just right crispness in cruise, off the line, etc. Never felt that 'crispness' that you feel driving a mercedes automatic e.g. or BMW and the DCTs are like manuals so not comparing those.
BUT when this Cadillac got that 10sp, I can't explain it other than the car is simply more enjoyable to drive. So I don't disagree with your point about 6 gears, it's not about the six gears, it's the experience and enjoyment of driving and this a10 so far has nailed it. I would like that in my fbody if I can get it. I went from a t56 to a th400 and have a 4l80e ready to go in when I get some time. I may just go to a MagnumF now that they are out, but would be neat to have that auto 'crisp' driving experience that the a10 provides in the fbody.
Old Jul 29, 2020 | 03:09 PM
RPM WS6's Avatar
How do you define "crispness" in this context? Are you referring to shift quality/specific transmission behavior as it relates to vehicle performance, or is this more about overall throttle response and/or the engine always seeming to be in the "sweet spot" due to the gearing of this unit? If the former, then this can certainly be duplicated (or better) with a well built older unit of 3 or 4 speeds...but since you've mentioned having a TH400 (and building one of those for excellent shifts is certainly not a problem for any competent builder) I'm guessing that's not the issue. So it must be more regarding the latter. While I haven't personally driven an A10 car yet, I can't say that I've ever felt that any sort of "crispness" was lacking from a well built/tuned A3/A4 transmission with an optimized (high quality) converter and final gear ratio.
But then it might also be that you're looking for a "manual" type feeling (one of more direct connection) from an auto, and that doesn't really come from a higher stall speed in one of the older units (in fact, that often provides the opposite effect - at least at part throttle). I actually don't care for manuals in general, so perhaps that's why I never felt like a properly set up auto was lacking anything of value, to me.
I'm interested in driving an A10 car now at some point, just to see if there is something which appeals to me as well. Honestly, I was not at all impressed with the A8 in the earlier 6th gen Camaros. That's the most modern automatic I've driven, and I definitely prefer a well built A3/A4 setup over the A8.
Old Jul 29, 2020 | 03:44 PM
383z's Avatar
I've seen two people put the new Gen 5 LT1 and 10 speed in a 4th gen Camaro. The transmission fits. Bad thing is neither one have got the car to start.
Old Jul 29, 2020 | 03:51 PM
War Prayer's Avatar
I get this, but at that point wouldn’t you just rather have the whole 6th gen with the 10spd attached? The 4th gen is missing the refinement and advancements in so many other areas that sticking an A10 in there for highway drivability and gas mileage is a little like smearing lipstick on a pig.
Old Jul 29, 2020 | 04:04 PM
kinglt-1's Avatar
I agree the A8 isn't great with the factory tuning, but a built A4 is nothing like a tuned A8 or stock A10 transmission...literally not even in the same ball park. Actually I prefer a tuned A8 over factory A10. The overall driving experience is night and day better. Much faster and crisper shifts...you can just hold the left paddle before you enter a turn and it will drop right into the optimal gear for the speed you are going. It is a lot more engaging to drive spiritedly. Stalled A4 cars feel like you are revving to the moon to putt along or stuck at 6500rpm when you go WOT....like a light switch, there isn't much in-between. Not really knocking them being I drove one for 10yrs and they are fun but the new Automatics are just better all around.
Yes which is why I have a 6th gen...however I still think it would be cool to have a A8 or A10 swapped 4th gen. Honestly the A8 is a beast once tuned.
Old Jul 29, 2020 | 06:50 PM
vorteciroc's Avatar
Duh...
The ECM and TCM alone will not do it.
The data lines are entangled into the other modules like a spider-web...
Thus I used the ECM, TCM, EBTCM, TCSCM, BCM, VCIM, IPC.
The TCSCM is not needed for a two wheel drive car and the EBTCM is probably not needed if the TCSCM is not used.
Old Jul 30, 2020 | 07:44 AM
This thread went from info to opinion reaaaal quick
