Removing torque convertor pilot bushing?
Old Aug 2, 2020 | 01:43 AM
funkyflynz's Avatar
Default Removing torque convertor pilot bushing?
Hey guys, 4 searches and couldnt find anything on this, im converting to manual (t56) and believe i will need to remove the torque convertor pilot bushing. Its sticks out quite a bit, but i did test fit the flywheel and clutch and theres a few millimeters of clearance. But i just dont feel comfortable leaving it in there. Can i just cut off the protuding part with an angle grinder or do i need to remove it completely? If so whats the best way to remove it?
Old Aug 3, 2020 | 08:54 PM
vorteciroc's Avatar
It is probably being held in by rust and debris.
It should come out with some light tapping from a mallet and pulling on it with some vice-grip pliers.
Old Aug 3, 2020 | 09:17 PM
01CamaroSSTx's Avatar
I was going to say I've never seen that on a crankshaft before and its probably held into place by rust so get a hammer and tap it off..
Old Aug 4, 2020 | 07:18 AM
MaroonMonsterLS1's Avatar
what they said^^
