Need help with step 4 on transgo hd2 4l60e shift kit
I'm not wasting an hour of my time to find the spot you want us to see.
Put a time stamp
For the instructions, step 4, I'm assuming you're referring to the accumulator valve and spring portion? At least based on the instructions I have in front of me.
Use ONLY the transgo supplied spring. Discard stock.
Put a time stamp
Put a time stamp
This is a light (low spring pressure) spring that will allow the Accumulator Valve-Train to exhaust more easily...
This helps to prevent a harsh shift up into 2nd gear, when accelerating lightly.
The "red" spring is firmer and will make this shift more abrupt/ harsh.
