4l80 help
Generally when a 4L80E transmission only operates in 2nd and reverse... there is no power going into the trans... or it is in "Limp-Mode" electronically.
It is not uncommon for some codes to be set to ignore via HP-Tuners...
Are you certain that there are NO DTCs???
I do not really feel that shouldn't be...
What else has been modified?
Is this a 4L80E from a 4 wheel drive truck that has no Output-Shaft Speed-Sensor?
Then it is not mechanically or hydraulically stuck in second gear.
When reverse and second work...
Mechanically and hydraulically, so would first gear and third gear (the only clutch packs that we do not know about at this point are Over-drive and Over-run, as well as the Intermediate band).
First gear uses the Forward clutch (and the Low-Reverse band in manual 1st)
Second gear uses the Forward clutch and the Intermediate clutch (and the intermediate band in manual 2nd... we do not know if this band works).
Third gear uses the Forward clutch, the Intermediate clutch, and the Direct clutch.
Reverse uses the Direct clutch, and the Low-Reverse band.
From this information... we know that 1st and 3rd gears operate because the shared use of clutches in 2nd and Reverse.
The 1st and 3rd gears are not electrically or electronically being operated.
