Trans cooler
Old Oct 30, 2020 | 07:05 PM
Blac94z28's Avatar
Default Trans cooler
Hello so I just picked up a double row trans cooler with aux fans for my A4 just having trouble finding a spot to run it, I know someone he done it or can give me a couple tip where to mount it
Old Oct 31, 2020 | 12:06 PM
klinznilk's Avatar
https://www.google.com/search?q=tran...w=1920&bih=910
Old Oct 31, 2020 | 12:21 PM
Blac94z28's Avatar
Searching is not the problem if you read the post from the link you sent none of which has a fan mounted to a car, only single row coolers with no fan running “dope style” or in front of a/c I’m looking for someone that has actual done it thanks
Old Oct 31, 2020 | 12:31 PM
klinznilk's Avatar
With the fan setup it's limited. Mine is mounted under the ttop holder in rear.
Old Oct 31, 2020 | 12:36 PM
Blac94z28's Avatar
I see my only options are the rear or in front bumper,so is your ran in series with the rad cooler ? Or do you just have the separate trans cooler
Old Oct 31, 2020 | 12:46 PM
klinznilk's Avatar
My radiator is bypassed. Straight from transmission to cooler and back to trans.
Inside front bumper i did not have any room at all even before installing a intercooler. I am running the derale 25row hyper cool remote mount
Old Oct 31, 2020 | 12:58 PM
Blac94z28's Avatar
I’ll have to figure it out but thanks much appreciated
Old Nov 2, 2020 | 07:03 AM
MaroonMonsterLS1's Avatar
I have put a couple WITH fans in the front driver's corner. Right behind/under the fog light.
Remove the fog light for some extra flow if need be
Old Nov 2, 2020 | 09:39 AM
Blac94z28's Avatar
you know I was thinking of that horizontally right? Do you have a pic ?
Old Nov 2, 2020 | 10:15 AM
No pictures.
Car is prettymuch tucked away for the winter. But it'll come out of the garage to get some work done mid-winter.
If I remember I'll grab some pictures for you but no promises
Old Nov 2, 2020 | 01:32 PM
Blac94z28's Avatar
No pictures.
thanks a lot when I mount it or mock it up I might take a couple pics and post them here if I dont hear back from you first
