Different Torque Converter?
Old Nov 1, 2020 | 10:37 PM
300_Deluxe's Avatar
Default Different Torque Converter?
Trying to figure out what to do with my torque converter. I’m going to be installing a 2004r behind my Lq9. The car is street/hwy driven only. Car specs below:
Rear end: 3.08
Rear tires: 275/40/18
TH350 > Upgrading to 2004r
Torque converter:<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Product Line: FTI Performance ESR Series Torque Converters, 9.5" diameter, Flash stall 3400-3600rpm
Cam specs:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: Idle-6,200
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 230
Advertised Intake Duration: 275
Advertised Exhaust Duration: 285
Intake Valve Lift with Factory Rocker Arm Ratio: 0.553 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.553 in.
Lobe Separation (degrees): 117
Looking back I still don’t think I understood enough to select a proper TC. When driving it shifts about 3500 rpm on normal take off from a light. Seems super high to me ( I guess I'm used to my old TC which was around 1800-2k rpms, I think). I’ve never taken the car to a dyno, so I can only guesimate the HP/Trq output. Just looking for opinions/recommendations on either keeping the TC I have now, in hopes it’ll be better with the 2004r, or putting a lower stall when I go for the swap. Ideally keeping rpms low on the fwy. Car is a '69 4 door Chevelle.
Old Nov 4, 2020 | 11:49 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Rear end: 3.08
Cam specs:
Do you have a link to that ESR Series converter you mentioned? The normal ESR series will not fit a 2004R. The ESRL Series will with a 27 spline turbine hub.
Feel free to shoot me a PM or email and we can further discuss converter options.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
