95 4l60e with 2003 lm7
1995 4l60E units are an old-ball year in terms of PCM control of the valve-body and oil-pump.
Physically you will need to adapt the transmission to the Gen III small-block chevy...
as the transmission is intended for a Gen I small-block chevy.
The easiest way to do this, is with a custom torque-converter...
along with using only 5 of the 6 bolts that attach the transmission to the engine.
