4L80e ISS and VSS
Old Dec 28, 2020 | 07:49 PM
paperboy326's Avatar
Default 4L80e ISS and VSS
Putting a 4l80e Behind my L92 in our scout build. The NP241 were using is manual speedo not VSS, so I checked the rear plug on my trans and no reluctor ring so will add that during rebuild for the VSS, the front sensor is the ISS. When I order my swap harness it should come with both as I need both right?
Thanks
Old Dec 28, 2020 | 08:18 PM
MaroonMonsterLS1's Avatar
Well, you didn't mention who is building the swap harness or what you asked for when ordering it.
Why wouldn't you just ask them if it will come with both
Old Dec 28, 2020 | 09:08 PM
Probably use BP Automatic or PSI. I guess I’m asking is that something that is standard or something I need to request.
Old Dec 29, 2020 | 07:11 AM
any 4l80e harness should have both sensors. Not gonna work without both.
But length could change.
Just call whoever you're ordering the harness from and talk with them.
Old Dec 29, 2020 | 08:09 AM
5.7stroker's Avatar
Harness? Can't you just make one using a pack of 12084912 PCM pins and some longer wire? There was some thread on here mentioning a $175 harness lol.....
https://lt1swap.com/4l60e_4l80e_harness.htm
The TCC Enable Solenoid Circuit "T" and the 3-2 Shift Solenoid Circuit "S" are not used on the 4l80E. Pull these two circuits out of the connector & move the TCC PWM Solenoid Circuit from cavity "U" to cavity "S". Seal the connector using RTV into the empty cavities "T" & "U".
Source a used Engine Coolant Temp (ECT) Sensor pigtail off pretty much any GM vehicle, Solder & Heat Shrink some wires onto it. Run them up to the PCM. The terminals on the harness are the same ones for the PCM mentioned above.
Locate cavities 22 & 23 of the Red PCM Connector, Pierce the silicone seal. remove the Terminal Locks, put in the two wires into 22 & 23. Polarity doesn't matter.
