4L80E modifications guide
I'm also fascinated with the 4L80e and watch every video I can find on it. Thank you for this.
My mods consist of:
91 Core
300m input shaft - oem intermediate
Rossler D3
CK Rollerized billet front hub
CK Upgraded Intermediate Plate with springs (TH400 style)
CK rebuild kit
TH400 Direct Piston with upgraded springs/6 clutch setup assembled from CK
Early TH400 (1964-66) reaction carrier with the "desired" roller sprag. Saw this upgrade on a few sites and found one on ebay
My mods consist of:
91 Core
Rossler D3
CK rebuild kit
Those very-early Reaction-Carriers are quite scarce now.
I only ask that you refer to the early style Reaction-Carrier as a "Sprag" type reaction carrier.
Referring to it as a "roller sprag" is going to confuse people who are not in the know... and probably have never seen the very-early Reaction-Carriers.
The two versions of this part, are the "One Way Roller-Clutch" type, and the "Sprag" type.
B. Not desireable
C. If you do want to use it despite A and B, get an E4OD sprag. It is a direct fit and will be stronger than the sprag that is in that reaction carrier now
Since the "One Way Roller-Clutch" type reaction carrier has not been a problem for me in 2,000+ HP builds... I have never tried to use the "Sprag" type in a high power application.
I keep the "Sprag" type, primarily for people looking to correctly restore their "Switch-Pitch Super-Turbine 400" Transmissions or 1964/ 1965 THM400 Transmissions.
I am now curious as to what your findings have been in regard to testing or research of the 'Sprag" Type reaction carriers.
I recall the largest Sprag used in the E4OD Transmissions being the Intermediate Sprag... I do not Recall the C6 using it... But the 4R100 might, hmm... or it went to a "Roller-Clutch" instead.
I would suspect this is the Sprag in which you are referring to.
its' statically applied in low gear, ramp type is much stronger.
sprag type is a novelty at best. If you happen to get a trans that has one and you're doing a budget rebuild, use the e4od sprag and it will likely be fine...at least as long as the 34 element direct drum sprag is good for.
But I wouldn't go out of my way to try to find one
I will have to inspect these further as they should not be statically active!
They should be dynamically holding or overrunning.
I will compare the next one with the sprag from a Ford E4OD.
I always enjoyed finding parts (bushing, bearing, etc) that are shared among unrelated transmissions.
As you know, the THM400 Low Roller-Clutch also fits the Ford AOD/ AODE based transmissions.
Unlike the 2nd gear sprag where it is overrunning in 1st then gets shocked into holding on a 2nd gear shift
Main usually breaks on the 1-2
as a general rule of thumb...I've seen them over 1000, between 1000 and 1200 I STRONGLY recommend it to customers, over 1200 it gets replaced with aftermarket.
when it comes to these transmissions. There’s so much that goes into these. I’m just passing along the info that has been graciously shared to me.
