4l60e stuck in 3rd gear
Old Feb 4, 2021 | 02:01 AM
Alexander Samuels's Avatar
Default 4l60e stuck in 3rd gear
I swapped a 6.0L lq9 into a 83 cutlass, I'm using a 4l60e transmission and the only drive gear it has is 3rd gear. I manually got under the car and put it in 1st gear and it still feels like it's stuck in third. It does have reverse. Anyone else experienced this problem.
Old Feb 4, 2021 | 02:02 AM
Old Feb 4, 2021 | 07:08 AM
2BFAST's Avatar
Do you have any DTCs? Sounds like its in default or limp mode.
Old Feb 4, 2021 | 07:20 AM
MaroonMonsterLS1's Avatar
no power to the trans
Old Feb 4, 2021 | 09:50 AM
P0650 code is the only thing showing up.
Old Feb 4, 2021 | 05:21 PM
bbond105's Avatar
You should delete one of these two threads so that all of the replies are in one place. As for your trans issue, you have an electrical problem.
Old Feb 4, 2021 | 06:25 PM
vorteciroc's Avatar
If you are only using one PCM for both the engine and transmission together, but the engine operates properly then as the other have stated... power is not being properly supplied to the transmission.
If you are piggy-backing two PCMs... then the PCM for the transmission may be dead.
Old Feb 4, 2021 | 06:53 PM
I checked the plug on the transmission and about 4 pin holes are hot when key is on.. does all the pins need to be hot
These are the wires i have coming out of the stand alone harness by my fuse box. I already hooked the obd2 wire up, this is whats left.
Old Feb 4, 2021 | 06:55 PM
dixiebandit69's Avatar
Why would someone piggy-back two PCMs for a simple combination like that?
I'm using 1 pcm and the transmission plug in has 4 pin holes thats hot while key is on.
Old Feb 4, 2021 | 07:27 PM
vorteciroc's Avatar
Lmao! People should not do this!
But people be Jerry-Riggin' all kinds of horrid creations that should not be!
I have seen people do some scary things...
Old Feb 4, 2021 | 07:28 PM
vorteciroc's Avatar
Can you post a photo of this?
Old Feb 4, 2021 | 07:30 PM
vorteciroc's Avatar
DixieBandit69: see what I am talking about!
Old Feb 5, 2021 | 01:14 PM
Old Feb 5, 2021 | 02:23 PM
Fix the mouse nest and get the wiring right and issues will likely go away.
Codes are typical of no power to trans, or criss cross wires giving false signal
Old Feb 5, 2021 | 02:58 PM
86CAMARO400HP's Avatar
Yea, it seems like the trans isn't getting power. It will only drive in third and reverse if no power is present. If you need wiring info lt1swap.com is a good place.
