600HP 4L60 or 4l80
Old Mar 29, 2021 | 05:25 PM
skidze01ss's Avatar
Truckdoug, I pulled the extension housing and this is what I got. Struck out on this one.
Old Mar 29, 2021 | 06:28 PM
vorteciroc's Avatar
You could use a "Counter-Bored" Slip-Yoke on that Output-Shaft.
Or you can turn-down the thicker-diameter area (where the O-Ring is) on a lathe to a diameter smaller than the splined section.
Don't remove too much/ make it too small in diameter as this will weaken the shaft.
Old Mar 29, 2021 | 06:46 PM
truckdoug's Avatar
make sure your tool is sharp! that sucker is made of some tough stuff
Old Mar 29, 2021 | 09:16 PM
skidze01ss's Avatar
Thanks for the input fellas. I have a fully splined slip yoke style output shaft on the way.
Any recommendations for a rebuild kit? I will more than likely upgrade the input shaft while I'm there.
