4l80e 1-2 shift slip
Old Mar 28, 2021 | 11:45 PM
RussWasHere's Avatar
Unhappy 4l80e 1-2 shift slip
Swapped in a junkyard trans no info on it every gear holds alright 1st-3rd hold alright 4th falls out at 115mph.
The only apparent issue is the 1-2 shift slips pretty bad WOT. shifts fine under normal driving but at wot it slips/takes longer than it should
Looking for possible causes/solutions to the soft/slipping 1-2 WOT shift
Old Mar 29, 2021 | 08:06 AM
MaroonMonsterLS1's Avatar
bet a dollar you didn't verify actual "full" level on the dipstick
2 causes
A. you're way low on fluid
B. clutches are pooped and you get what you deserve for using a junkyard transmissions
Old Mar 29, 2021 | 08:13 AM
2 causes
You would win a dollar in that bet... that being said if I put another 1/2 gallon in it and see if that changes anything would it hurt it in the long term if it ends up overfilled? Would turning the EPC solenoid screw 1/8 a turn do anything witch way increases pressure on the EPC solonoid screw
Old Mar 29, 2021 | 08:32 AM
over full can be just as bad as under full
epc screw is usually a hacky way to get more pressure, but it does work
Old Mar 29, 2021 | 04:47 PM
truckdoug's Avatar
if you have the pan off, a $12 spring from CK is a low-stakes way to see if a line pressure bump will help. EPC is only gonna get a 10-20 psi in a stock PR unit.
