Vacuum Modulator Under Boost
Old Apr 16, 2021 | 11:04 AM
Woodylyf767's Avatar
Default Vacuum Modulator Under Boost
What happens if the vac modulator sees boost? I'm guessing people are running a check valve so that the vacuum modulator only sees vacuum. When the check valve closes, what pressure would the modulator see?
Old Apr 16, 2021 | 11:42 AM
vorteciroc's Avatar
Yes, if you are using a stock type valve-body...
Then a check valve would be needed.
It would work like the check valve that goes into a vacuum power brake booster.
