New Vette Tranny finally the Savior for A4s??
Originally Posted by Naked AV
Not to mention the gearing sucks!
Guest
Posts: n/a
Originally Posted by James B.
I like the closer ratios of the 80 more than the wider range of the 60. No bog after shifts. Two more gears, one at the bottom, one at the top would be ideal. I use a Gear Vendors OD with the 80 and a 4.56 rear end with 29.4" tires. Good launch, good cruising, close ratios, and just about bulletproof.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
