Circle D 4k Stall
Old Jun 22, 2021 | 09:20 AM
Projekt98WS6's Avatar
Default Circle D 4k Stall
I have a 2001 ws6. LS2, 799 heads, ls6 intake, ms4 cam, deka 60lbs injectors, 4l80e, Cirlce D Pro series billet back 4k stall, 1 7/8th's long tubes to a cutout and flowmaster(got it for free), its on a 28 inch tire and has a moser 12 bolt with 4.56's. car pulls hard but just does not feel like a mid 11 car like i feel like it should be. Im starting to wonder if the converter is the wrong choice. i know the stall size is atleast the recommend size being a 4k but using a dragy on the street which gives me my estimated quarter its only at like a 12.3 at 110. i feel like this car should be trapping in the 116-118 range.
Old Jun 22, 2021 | 09:31 AM
98CayenneT/A's Avatar
How high are you spinning your setup?
What was the da?
compression ratio?
Old Jun 22, 2021 | 09:49 AM
What was the da?
compression ratio?
i havent calculated compression ratio. limtier is set at 7100 shifts 6850-6900 and DA im guessing is like 2500 im in ohio where its pretty hot and above elevation.
Old Jun 22, 2021 | 09:55 AM
bug this thread and pop over to my other one. i didnt know they were going to move my post into the auto section where i had one already
Old Jul 1, 2021 | 07:39 AM
jhshnh's Avatar
Is the converter still slipping heavy beyond its stall rate?
Old Jul 6, 2021 | 10:15 AM
i think when we did that math it was like a 14% slip. seems kinda high to me. but car goes to the dyno thursday suppose i can find some more out. hopefully not the converter. id hate to pull it back out. just had it refreshed and stalled.
