Btr 3000 to 3200 stall converter
Old Sep 8, 2021 | 07:48 AM
916montels's Avatar
Default Btr 3000 to 3200 stall converter
Looking to get the BTR 3000 to 3200 stall converter, has anyone used this one and what's your opinion on it?? It's back ordered at the moment but should be in soon I was told.
Old Sep 9, 2021 | 08:40 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
BTR sells several different brands of converters. Post up a link or something more descriptive so we know which converter you are talking about so we can weigh in.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Sep 9, 2021 | 05:49 PM
916montels's Avatar
True didn't think about that, here's the link appreciate the info guys.
https://briantooleyracing.com/btr-4l...p3413exhs.html
Old Sep 9, 2021 | 06:09 PM
vorteciroc's Avatar
I am a big fan of the Guys at Brian Tooley Racing.
I often find their Valve-Event calculations/ recommendations to be very similar to my own.
I like where their heads are at!
However, if you are looking for a Torque-Converter...
I would highly recommend just calling Dalton at FTI, and have him set you up with what you need.
Good luck!
Old Sep 9, 2021 | 08:40 PM
916montels's Avatar
Sounds good I will give them call and see what they recommend thanks
Old Sep 9, 2021 | 11:33 PM
916montels's Avatar
But has anyone used the btr stall?
Old Sep 10, 2021 | 02:23 AM
vorteciroc's Avatar
You are most welcome!
I personally have never had a Vehicle, or Power-Train that used a Torque-Converter of a BTR Brand (Brian Tooley Racing).
I do not believe Brian has his own TC Products... if anything he probably puts his name on another manufacturers TCs (just like he does with Valve-Springs).
In terms of using a "High Performance" Torque-Converter, I have used:
-Neal Chance (I only use these with serious Power).
-FTI (My personal preference).
-Pro-Torque, Yank, Circle-D, Edge, and TSI.
I strongly recommend staying away from inexpensive/ budget/ cheap Torque-Converters...
Commonly found from B&M, and TCI.
Should you wish to get into specifics... It would be very helpful to know what model Transmission you have, and also what Vehicle.
Old Sep 10, 2021 | 12:13 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
^^^ that.
??? vehicle, trans, intended uses, rear gear ratio ???
Old Sep 10, 2021 | 09:47 PM
916montels's Avatar
95 impala ls swapped lq9 6.0 btr stage 4 799 heads 373 gear in the rear, 4l80e trans, nothing special just a weekend cruiser not going to the track or anything like that
Old Sep 10, 2021 | 09:53 PM
vorteciroc's Avatar
Alright, for a 4L80E Transmission...
I would also recommend Jake's Performance:
Web-Page HyperLink
They are a great Automatic Transmission business, and the 4L80E is one of their specialties.
They are fully equipped to make custom 4L80E Torque-Converters in-house.
I would recommend FTI or Jake's Performance, for your Vehicle.
Good luck and have fun!
Old Sep 25, 2021 | 11:16 PM
916montels's Avatar
Ended up give jake's performance a call and order a stall from them thanks for the insight guys
