4l60e Interchange
Old Sep 24, 2021 | 04:17 PM
Hurricane2112's Avatar
Default 4l60e Interchange
I have a 1994 gmc Sonoma 4x4 4.3 liter an the transmission has Burnt up. I’ve read that you can only use a 93-94 trans an I’ve read that you can use up to a 99. Im wondering what years I can use or can I only use a 93-94
Old Sep 24, 2021 | 06:21 PM
vorteciroc's Avatar
With the 1994 Sonoma being entirely stock...
You are going to need a 1993 or 1994 Transmission.
I recommend finding another Four Wheel-Drive 1994 Transmission, over a 1993 Transmission.
Do NOT purchase a Two Wheel-Drive Transmission.
The 1995 Model is different from the 1994 Model...
as well as the PCM and OBD-1/ OBD-2 Systems.
I am assuming that you do not want to have the Transmission rebuilt...
and are hoping that a Junk-Yard Transmission will work for you.
Good luck!
Old Sep 25, 2021 | 09:37 AM
Thanks for the info yea I’m just going to have mine rebuilt
