Yank ss3800 or TCI ssf3500
Originally Posted by DannoWS6
Man this is a tough decision. I keep going back and forth. If I were to get the TCI I'm worried that I might keep wondering if I should of got the yank. I mean it's a 9.5 inch converter, 21 blade strator, more efficient, and its general more streetable but may produce slightly better numbers at the track. I want to pick the right one the first time.
It seems if money was not a factor people would have probably opted for the Yank converter.
On a side note GM high tech performance has a bolt on ls1 running 12.3's with the ssf3500. But would it of been better with the Yank?
loss MPG with converter?
thinking about a 3500 for my stock a4
while driving normally or cruising on the highway, does the miles per gallon go down and how much?
what about driving in the snow or rain, does it rev up the RPM and takes off? ( = doing multiple unwanted donuts in the snow) or can i easy it out from a stop? thanks
Retired Street Racer
Originally Posted by mdblackz28
gm high tech performance's stall was a 3800 if i recall...is there much difference in the TCI 3500 vs the TCI 3800?
The part number they had was 242932
But TCI's site doesn't mention the stall speed on that part number
