First 4L80e hop-up?
what would be simple upgrades I could perform? FWIW, I don’t know chit about trannys.
thanks,
jimbo
it will most likely be in your wallet's best long term interest to just overhaul it now.
The only real benefits you can do right now would be valve body modification...transgo being the most popular...but there needs to be many steps left out of a transgo kit imo
I don’t want to do any but filter, tail seal and a new dipstick and seal until I know it works properly. If it does, than I will do a transgo shift kit
condensation is a real mean mistress.
if you wish to just run it...go ahead and roll the dice and run it. Might be A-OK
filter and pan gasket are ok...but why such a hard on for the tail seal? if you're worried about it being hard/dry/brittle and not sealing after sitting for so long...I've got news for you about alllllllll the seals inside the unit
Moroon Monter LS1,
I know. I just want to replace cheap easily replaced pcs until I know it works. I know it’s a crapshoot even buying this, it just sorta happened. I generally tend to buy new or rebuilt pcs as I hate throwing $$$$away
