Stand alone transmission controller or factory PCM?
Old Jan 1, 2022 | 01:26 PM
99JT's Avatar
Default Stand alone transmission controller or factory PCM?
not an ls but figured this would be a good place for help. building a 2000 chevy pickup with a carbureted 350 and 4l80E. in the past i have used the factory black box PCM to control the trans with a carb but was thinking about going with a stand alone controller for this one for a quicker and cleaner install. is a stand alone controller worth the money, any opinions or recommendations appreciated.
Old Jan 1, 2022 | 02:16 PM
pdxmotorhead's Avatar
The stand alone will let you tune the shift points much better,, you'll just have to do a lot of research on the features you want. When I was shopping for my swap I looked at several, seemed to be a decent amount of choices for reasonable cost.
Several have some of the nifty features like trans brake supported as well.
Old Jan 2, 2022 | 09:09 AM
99JT's Avatar
Thanks. did some looking around and so far the US shift controller seems to have everything i want and is decently priced or the megasquirt. Dose anyone have any experience with them?
Old Jan 3, 2022 | 10:54 AM
truckdoug's Avatar
i have used to us shift quick 4 several times. it's easy to use and pretty robust. just need a TPS and RPM signal iirc
