Has anybody used the Superior Pressure Riser?
Old Jan 18, 2022 | 05:30 PM
matermark's Avatar
Default Has anybody used the Superior Pressure Riser?
Any comments on this? This distributor never includes much info on each product page...
https://www.buffaloengine.com/catalo...pressure-riser
or the fixed non-adjustable:
Thanks.
Old Jan 19, 2022 | 07:21 AM
MaroonMonsterLS1's Avatar
it's a resistor
if you wanna pay a bunch of money then wait a week for a resistor to be delivered...go right ahead
the one with a **** is just essentially a rheostat.
If you're doing other valve body modification and changing boost valve/spring there should be no need for this piece
Old Jan 19, 2022 | 09:29 AM
matermark's Avatar
Originally Posted by MaroonMonsterLS1
it's a resistor
Thanks Monster! I thought maybe you already had a wiring schematic decoded for the switchable/dial version... and why would they recommend the performance setting only part-time? Is it so high a pressure setting?
Old Jan 19, 2022 | 11:11 AM
it's JUST a resistor.
That's it
add resistance to the EPC circuit and the amperage at the EPC itself will go down
less amperage @ epc = more pressure
Running around full time on effectively 0 EPC amperage is gonna rattle your fillings out of your teeth on the shifts. it isn't needed
