4l80e rebuild kit recommendation
Old Feb 12, 2022 | 04:22 PM
MAjdi ALharthi's Avatar
Default 4l80e rebuild kit recommendation
Hi everyone as titled what would be a recommended rebuild kit for 4l80e transmission
I believe my transmission get some water in it because the oil color kind of light pinky, if this is the case what parts need (must) to be replaced.
will stock 80e survive 500whp
Old Feb 12, 2022 | 04:38 PM
bbond105's Avatar
All of the frictions and bands would need to be replaced if coolant got in it, along with a gasket and seal kit at a bare minimum. Whatever It Takes Transmission Parts should have everything you need. You can order online or fine a nearby location and get the parts from there.
Old Feb 13, 2022 | 09:25 AM
5.7stroker's Avatar
You are in Houston? Just head over to WITT per bbond's advice.
3739 Yale St, Houston, TX and sign up for an account. Parts will be cheaper than if you walk in off the street.
Old Feb 13, 2022 | 05:41 PM
Thank you 🙏🏻
Old Feb 13, 2022 | 05:56 PM
I will check that Thankyou
