4L80E Forward Drum Question
I’m currently refreshing my 4L80E and noticed the original wave plate can now spin freely and isn’t engaging the lugs (all was fine on last rebuild). I bought a .060” th400 wave, and it still spun. A .090” direct steel doesn’t spin, but I don’t feel comfortable running it as it’s barely engaging the teeth (sideward pressure can still lodge it enough to concern me) My question is: What could be the cause of this, and what should be next step be here?
Anyways, do you think I should just order up a new piston and go from there? I see no issues with the drum.
edit: I also really didn’t want to take the direct piston back out again and shove it in the fwd, I fxkn hate that little snap ring. If that’s what you meant by the fitment of direct piston
I also made sure to keep pressure on the piston so it’s 3 feet/tabs were in contact with the bench
A Inboard Chamber and an Outboard Chamber.
When we Dual-Feed the Direct Drum, we eliminate the Seal that separates the 2 Chambers of the Direct Piston.
The Forward Drum is usually left Stock...
as both Chambers have a slow flowing Bleed Orifice between the Chambers that soften the Shift into Drive from Park.
The Inboard Chamber of the Forward Piston is smaller than the Direct Piston.
As such they are not completely identical/ interchangeable.
If you install a Direct Piston into the Forward Drum, the Inboard Chamber will not be sealed/ separated from the Outboard Chamber.
Doing so is fine for Very High Stall-Speed Torque-Converters, Trans-Brake use, and or Off-Road/ Race use Only applications.
I do not recommend it for Stock-Type/ Lower Stall-Speed Torque-Converters, or Daily-Driver Vehicles.
I’m currently running extreme automatic’s reverse pattern transbrake valve body (boost valve shimmed to achieve ~180psi line pressure), and one of Jake’s converters spec’d for a ~3500 stall 900hp turbo 6.2L ls application. I have the direct dual fed (sealing ring left off center support, ~.050” bleed hole, and valve body does the rest). As for the forward drum, I have the center sleeve seal removed, which already firmed up the shift to drive. For my application, as it’s my personal vehicle, I don’t mind how hard it slams into gear as long as functionality is not altered. If I do run the direct piston in the forward drum, is there any other alterations needed to be made? Firstly, would I use the forward or direct spring+retainer? Also, if there is anything else needed in my application, I would greatly appreciate your input. Thanks again.
look at it and you will see
the middle seal on the fwd drum is just there to slow the apply rate of the piston...making the "garage shift" less agressive...it does this by sealing off the inner from outer chamber and making all of the apply oil between the two flow through an orifice in the drum
SO...the two chambers are connected...just via a little bit smaller hole that controls the apply rate of the piston. The intention was to keep it from "slamming" into drive.
Using the direct piston is fine and will just result in a slightly more firm shift from PRN to D as the fwd clutch engages.
