Overdrive in auto 4l60
Old Mar 10, 2022 | 10:01 AM
danyyynnygarrr's Avatar
Default Overdrive in auto 4l60
Which D do I drive on for regular daily driving the one with the circle around it or the one without it thanks
Old Mar 10, 2022 | 11:22 AM
bbond105's Avatar
The one with the circle around it. If you drive around with the shifter in the D without the circle the trans will not shift into overdrive, trans will only shift 2 times. With the shifter in the D with the circle around it the trans will shift 3 times, with the 3rd shift being overdrive.
