4.3 transmission mate to 4.8
The following users liked this post:
Overtime (11-08-2023)
What 4.3 Transmission? The NV3500? The 3500 is the same pattern as the muncie, which would bolt up to the LS.
https://www.s10forum.com/threads/mun...nv3500.482784/
https://www.gmt400.com/threads/nv350...22-swap.52818/
04gmc83, see if the bellhousing # is the same, and if it has the hole at the very top. Also see if the input shaft is splined all the way to the tip (300mm converter) without stepping down to a smaller diameter (298mm converter.) If hole at top and fully splined I believe it should work. Make sure removable bellhousings are the same depth. Hope this helps.
I used my 2000 V6 Sierra 4.3 bellhousing bolted to a Performabuilt 4L60 when I swapped to a 2005 LQ9 V8
Attachment 712198
