Old Pontiac Th350 transmission with a Ls 5.3 Engine
Old Apr 29, 2022 | 11:52 AM
KyleKetterhagen's Avatar
Default Old Pontiac Th350 transmission with a Ls 5.3 Engine
I am curious to know if my th350 transmission and a 5.3 Ls will mount up properly. Are the bolt patterns the same?
Also what specific items do i need for this to work? I know I need some sort of spacer and grade 8 bolts, but what else?
Old Apr 29, 2022 | 12:13 PM
bbond105's Avatar
This link should answer your questions.
All about Flexplates, Converters, Transmissions and Spacers - LS1TECH - Camaro and Firebird Forum Discussion
Old Apr 29, 2022 | 08:06 PM
MaroonMonsterLS1's Avatar
if you have a single pattern BOP case th350...no
if you have a dual pattern BOP/Chev case...yes
if dual pattern...treat it like any older GM trans...follow the sticky linked above
