Transmission
Old May 4, 2022 | 05:39 PM
Jamison hammette's Avatar
Default Transmission
I have a 4l60e in my 2000 gmc yukon i pulled it and replaced it wit a 4l60e from a v6 motorchanged the bellhousing over and converter but it still acts as if all gears are neutral
Old May 4, 2022 | 05:41 PM
dixiebandit69's Avatar
We need more details.
Why did you change the original transmission? What was wrong with it?
Old May 4, 2022 | 05:45 PM
My original trans burnt out
none of the gears worked
Old May 4, 2022 | 09:25 PM
tayto's Avatar
kind of like the same problem you are having now?
Old May 4, 2022 | 09:59 PM
bbond105's Avatar
Isn't the stator support on a V6 transmission shorter than the V8 transmission?
Old May 10, 2022 | 08:15 AM
Dynamic396's Avatar
The V6's use a 298mm input shaft and short stator. The V8's are a 300mm shaft and long stator.
