4l60e tcc apply issue
Old Jun 7, 2022 | 09:20 AM
jushu32's Avatar
Default 4l60e tcc apply issue
So I got a 1993 4l60e that I rebuilt, and after I first installed it my brake switch was bad so I had no lockup, back then I didn't know enough to fix it right away and drove it for a short while. After fixing it, now when my oil gets around 160° then my lockup gets soft and if I blip the throttle a tad then it slips a bit. I've changed out the converter clutch valve with the sonnax one already, do you guys think a leaking input shaft o-ring could be my issue? I've put the pressure gauge on it and I can see no noticeable drop in lockup
Old Jun 7, 2022 | 05:44 PM
mrvedit's Avatar
Moderator
The big question is: did you replace the o-ring? The fact you are asking makes me think you are unsure of its status. Yes, a leaking o-ring could cause TCC slippage, as could a worn out TCC within the torque converter.
Old Jun 7, 2022 | 06:14 PM
jushu32's Avatar
Sorry, yes I did replace it, but I'm wondering if it got damaged on install. And yea I think I've narrowed it down to that or converter defect now.
