Need expertise help
I kept the same flexplate and notice I didn't have clearance for the starter so I change it with the a flat flex plate and work fine.
I bolt up everything but my transmission 4l60e went out, I grinded the tip of the drum assembly, what would I need to fix the problem. What could be the problem??? please help I'm new at these.
Note: at first i thought i didn't push the torque converter all the way so i bought another Trans with warranty and made sure I pushed it all the way in this time. but it still grinded the drum assembly its a ( 300mm)
sorry if I didn't explained myself good enough..
