97 4l60e work in '00 z28?
but oh wait there's more than one 4l60e and they aren't all interchangeable and I've purchased a rebuilt 1-piece case 4l60e that from what I was told came out of a '97 camaro. I'm pretty strapped for funds right now and the nice gentleman refused my request for a refund... 🙄 so can I make this trans work in my car? I've searched the internet high and low and I think I understand that maybe you can do it but I can't find a clear answer anywhere to my exact problem. The bell housing of this trans has an angle cut out of it at the bottom like a 45 degree angle and the correct trans is just bolted flush all the way around. I've been told there a "dust cover" you can buy to fill that gap at the bottom of the bellhousing. Next there's the tailshaft housing. On the correct trans for my car there are lateral bolt holes to bolt to the torque arm going down the middle of the car and this trans doesn't have those. Can I buy just a tailshaft housing or do I have to also swap output shafts? I have a torque converter for the trans I have but my flex plate is from the correct 4l60e cause it came on the car. Last question I promise 😬: do I need some kind of adapter to go between the flex plate and my torque converter? If so please for the love of God tell me what it is cause I've been working on this car for the last year and a half and if I can get a trans in it I can finally drive the God forsaken thing and I'm seriously broke after buying parts for it to get it to this point. Any help is so very appreciated 🙏 I just really wanna drive this car lolhttps://www.summitracing.com/parts/sum-704004
Dont worry about the angle cut at the bottom of the trans you dont need the "dust shield" unless you have kittens running around....
Im not sure on the wiring of the trans internally, I think there the same but I would make for sure before installing it unless you need to swap something around, hopefully someone more savvy in that department will reply.
https://www.summitracing.com/parts/add-712500a
Cause that item comes with the spacer from post number 2 plus the flexplate adapter or am I wrong? Thanks guys so frigging much. I love this forum. Yall are lifesavers!
As for the adapter for the torque arm, I am unfamiliar with. I never had to adapt that. So you'll have to take LS7colorados word on that.
I get my flexplate and hub adapter from Speedway. The flexplate is SFI rated and thicker than stock. The hub adapter is a nice piece as well.
Can't send you a PM for the link. If I post it on here it'll probably get deleted since Speedway isn't a sponsor.
So, are you using the converter that came with the '97 trans or something compatible?
Your question about the adapter is answered in post #1 of this sticky: https://ls1tech.com/forums/automatic...s-spacers.html
Good that you have a new flexplate but you probably did not need it as the existing one could have been drilled out to work. (Even elongating the 3 mounting holes is generally enough.)
As SAPPER stated, all 4L60E/4L65E from 1996 (first year of PWM) through 2005 (last year before ISS came out) are electrically compatible. And up through 2008 (some 2009?) will work with a 1998-2004 PCM.
